Re: farmall C 3 point conversion?
Posted by Haas on March 20, 2003 at 17:12:56 from (152.163.189.203):
In Reply to: farmall C 3 point conversion? posted by jer on March 20, 2003 at 09:02:58:
Get one that has it's own hydraulic cylinder. If it works off the touch control rock shaft, the lifting capacity is limited, as well as the rods or bars that go back to the hitch are in the way of your mounting the tractor. I have a 3 pt on a C that works off the rock shafts and the most you can lift is 500 lbs or so.
Post A Followup
: Re: Re: farmall C 3 point conversion?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
