Re: Re: Re: 460 PTO will not stop.
Posted by Tim Malin on March 20, 2003 at 17:27:57 from (207.190.93.143):
In Reply to: Re: Re: 460 PTO will not stop. posted by Ohio Dave on March 18, 2003 at 15:50:49:
That definately sounds like a (if there is such a thing) linkage between your lever and your PTO clutch. When you can stop it by really pushing on the lever and has a little torque (like riding a clutch) you need to fix that for your own safety. Good luck and thanks for the post.
Post A Followup
: Re: Re: Re: Re: 460 PTO will not stop.
