Re: Coolant blockage
Posted by Hugh MacKay on March 21, 2003 at 08:34:43 from (209.226.106.42):
In Reply to: Coolant blockage posted by Wayne H. Thompson on March 21, 2003 at 06:21:14:
Wayne: I don't have the answer to your question. I have a gut feeling using stop leak on a thermosypon is a nono. If this is right through system about only way I see you could remove it and be relatively sure you get it all would be remove the head and use steam. I don't think you could be sure by just attacking it from the ports to radiator. I would be afraid of not getting a build up off around 3 and 4 cylinders. Just my thoughts.
Post A Followup
: Re: Re: Coolant blockage
