Re: 230 rear end leak
Posted by Hugh MacKay on March 22, 2003 at 03:54:48 from (209.226.247.84):
In Reply to: 230 rear end leak posted by TerryC on March 21, 2003 at 20:16:59:
Terry: Having never had that size tractor, not certain. Larger tractors had cap on end of axle carrier and around axle. Just remove that cap and seal is right there. The unfortunate part is you have to remove rear wheel to change it. When you have the wheel off pay particular attention to movemnt of axle in carrier. Bearings may have some wear thus causing seal leak. If axle has no movement (up or down, in or out) in there I would replace seal and keep on tractoring.
Post A Followup
: Re: Re: 230 rear end leak
