ned machanic help/ and yearon F-30
Posted by Okla/Kans Bill on March 22, 2003 at 14:48:42 from (209.240.198.63):
what year is an F-30 FB 27797. Im told a 37 model, and also, How in the h___ did they get that kotter key in the spline shaft in the hex nut just outside the clutch and pressure plate housing. I was hoping to get the cover off so that I could (hopfully) find a hole in the flywheel or the flywheel riding inside the bolt pattern of the bolts holding the clutch housing to the engine which, I guess cause the rear main bearing is gone ( I believe) is causing the engine to vibrate enough to loosin those bolts
Post A Followup
: Re: ned machanic help/ and yearon F-30
