Re: Grabby clutch in Farmall A
Posted by Hugh MacKay on March 23, 2003 at 17:54:13 from (216.208.58.165):
In Reply to: Grabby clutch in Farmall A posted by BEL@IN on March 23, 2003 at 13:18:31:
I gather that this not a new clutch, correct? Is it the heavier clutch with 6 springs in presure plate. My 130 and 140 both had Rockford clutches from new and never seemed to be a problem. However, when I put that same heavy clutch in Super A, I found it was quite vicious when letting clutch pedal out for some time. It has been about 5 years now and is some better. It is still not as smooth as others. The original clutches in Super A's had only 3 springs in presure plate. I have often wondered if the flywheel is somehow not quite right for the heavy clutch? Just a thought.
Post A Followup
: Re: Re: Grabby clutch in Farmall A
