Re: charging system on Super M
Posted by Steve - IN on March 24, 2003 at 07:11:47 from (12.222.31.186):
In Reply to: charging system on Super M posted by jack on March 24, 2003 at 05:21:41:
jack,
You can also change the regulator inside the Delco's for one that "trips" at lower RPM. An external regulator might be adjustable to charge at lower demand levels also.
Otherwise, Bob M's fixes are cheaper, easier and more in keeping with the level of problem you seem to have.
Steve
Post A Followup
: Re: Re: charging system on Super M
