Re: Cyber clutch ain't the same as old'n for 140?!?
Posted by Gary-Miss on March 24, 2003 at 15:56:36 from (205.188.209.78):
In Reply to: Cyber clutch ain't the same as old'n for 140?!? posted by Mitch in NC on March 24, 2003 at 14:13:22:
I've used them both ways with no problem. The springs are there for shock absorbing purposes. It is a good idea to slide the new disc on and off the transmission input shaft several times for two reasons. 1. They have been known to give you the wrong disc. 2. Sometimes, the disc kind of wears to one spot closer to the flywheel, just dirst, not wear and it will have a tendency to not want to "float"on the shaft. Doesn't release real well. A few slides helps this.
Post A Followup
: Re: Re: Cyber clutch ain't the same as old'n for 140?!?
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
