Re: FARMALL M RIM STYLES
Posted by Dave on March 25, 2003 at 05:38:06 from (64.108.72.248):
In Reply to: FARMALL M RIM STYLES posted by Ed Hadaller on March 24, 2003 at 21:19:20:
The correct rim for your M is the single rib . the rib is 2 inches across. The 2 bevel rim came from a Farmall 400 or a JD. Look at the cast wheel with the double bevel . It will have a different type of lug. You will need to match the other cast hub to use the proper rim. A used cast center is not to costly. A pair should be around $50.00 to $100.00. Plus you need to match your single ribed rim. Hope this helps you. Dave
Post A Followup
: Re: Re: FARMALL M RIM STYLES
