Re: 350U Overcharging
Posted by Bob M on March 25, 2003 at 16:13:50 from (66.66.123.133):
In Reply to: 350U Overcharging posted by Mike on March 25, 2003 at 16:06:30:
Mike - Probably a bad voltage regulator. Pull the wire off the "F" terminal at the regulator with the motor running. If the ammeter drops to near 0 or shows a small discharge the regulator is at fault. If it still charges hard there's either a short in the wiring between the regulator and the generator or else a problem inside the generator.
Post A Followup
: Re: Re: 350U Overcharging
