Farmall Tractors Discussion Board
Re: Re: Super C fast hitch plow
Posted by Kim Wm. Jeppesen on September 10, 1999 at 19:31:35 from (12.75.131.5):
In Reply to: Re: Super C fast hitch plow posted by Curt Cooke on September 10, 1999 at 07:11:04:
I also own a fast hitch Super C and plow. I believe the solution is the left touch control. My tractor is 150 miles away right now but if memory serves me the left control is to adjust the tilt of the hitch. This adjusts how level from front to back the plow. You need to have both touch controls hooked up to the plow. One adjusts the tilt of the plow from side to side and the other adjusts the tilt front to back. I remember when plowing last fall that when I raised the plow out of the gound when it was correctly adjust that it was just barely above the ground. I hope this helps.
Post a Followup
: Re: Re: Re: Super C fast hitch plow
