Re: Re: Re: Re: Re: Any quick advice on 300 utility
Posted by dick on March 27, 2003 at 08:49:41 from (65.59.18.249):
In Reply to: Re: Re: Re: Re: Any quick advice on 300 utility posted by Sean in Calgary on March 27, 2003 at 06:46:57:
If you have the operator's manual, see page 35, the steering box lube point is #40. Takes SAE 80 gear oil, fill to the top of the fill hole, which is near the top rear of the steering gear box on the left side of the tractor. Capacity is 1-3/4 pints. If it hasn't been filled within living memory, the oil's probably going to run out the seals at the bottom of the gear box, but that's another problem. Good luck.
Post A Followup
: Re: Re: Re: Re: Re: Re: Any quick advice on 300 utility
