Re: Ammeter Needle Jumping
Posted by bill b va on March 27, 2003 at 11:28:45 from (209.240.198.63):
In Reply to: Ammeter Needle Jumping posted by RET on March 27, 2003 at 04:17:53:
who rebuilt the generator ? if rebuilt and tested by a good shop it should be ok . other wise if communitator is out of round or insulation between segements is not under cut it will make the brushes bounce thus causing pulses . also shorted armature windings causes problems . is this a 6 volt generator you are using with a 12 volt regulator ? the external meter you used was it a amp meter commected in series between the regulator and battery ? have you tested the charging voltage to see if it is steady at approximately 14.5 volts?
Post A Followup
: Re: Re: Ammeter Needle Jumping
