Re: CHECKING CHARGING
Posted by Bob M on March 28, 2003 at 09:41:24 from (165.170.128.66):
In Reply to: CHECKING CHARGING posted by DANWV on March 28, 2003 at 08:38:22:
Dan - Here's how I'd proceed: First, test the ammeter by turning on the ignition or lights with the motor stopped. If the ammeter is working it will indicate -4 amps or so (ignition) or -10 amps or so (lights). If the ammeter stays centered with this test, place a strong magnet close to the ammeter lens. If the ammeter needle now moves away from 0 - which direction doesn't matter - it's wired wrong. And if the needle still doesn't move, it's stuck - time for a new ammeter! To your other question, you can test the generator by temporarily grounding the generator "F" terminal with the motor running at full RPM. If it now charges (ammeter indicates charge, or a voltmeter across the battery shows 6.8 volts or more) the generator is OK. Problem then is in the regulator or wiring. If grounding the "F" terminal has no effect then the generator is at fault. Rebuilding a generator depends on the nature of the problem. If it's simply worn out brushes, installing new brushes and polishing the commutator will bring it back. However if the commutator is burned/pitted, or there's an break in a field or armature winding, best take it to an alternator shop for repair - it'll usually cost you less than buying a rebuilt generator.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
