Re: Radiator removal
Posted by Tim K. on March 28, 2003 at 14:50:17 from (12.217.168.45):
In Reply to: Radiator removal posted by Bob on March 28, 2003 at 07:27:10:
Drive a chisel in the opening of the joint and it will slide out easier but watch the joint as you turn the shaft out to make sure it is sliding out or you will bend or bust the steering post. Check your water pump bearings for wear while your radiators off just for the heck of it.
Post A Followup
: Re: Re: Radiator removal
