Re: 300u will not start/other questions
Posted by matt_mn on March 28, 2003 at 17:46:31 from (206.10.58.183):
In Reply to: 300u will not start/other questions posted by James in MO on March 28, 2003 at 13:46:42:
I'll agree with the last comment that cleaning should help. Wire is a good trick. Take out all the plug type screws so you can access just about all the ports. Poke the wire down these ports. Use carb cleaner of corse and blow all ports and holes with compressed air and a blow gun. I wouldn't go throwing that carb away just yet. Replacements aren't cheap. Also are you getting good flow of fuel to the carb bowl? Just some suggestions. Good Luck
Post A Followup
: Re: Re: 300u will not start/other questions
