Re: Radiator removal
Posted by Haas on March 28, 2003 at 18:15:51 from (166.72.245.66):
In Reply to: Radiator removal posted by Bob on March 28, 2003 at 07:27:10:
As the others said, the steering shaft has to be taken loose at the universal joint to remove it. Once that is loose, you can take the big plug out of the front of the steering gear housing and screw out the worm gear. The worm gear and the shaft are all one piece so there is no taking them apart. On the front of the worm gear, there is a ball bearing(thrust bearing) held on by a castle nut and a washer. While you have it out check the bearing for play. If it has any play in it, replace it. The bearing is cheap and any play or wear will cause play in the steering system.
Post A Followup
: Re: Re: Radiator removal
