Re: Re: F 20 OR F30
Posted by Dean E on March 29, 2003 at 03:08:21 from (152.163.189.203):
In Reply to: Re: F 20 OR F30 posted by Photo Hound on March 28, 2003 at 20:37:25:
Where the bell housing bolts to the frame the 20 has one bolt on each side and the thirty has two bolts on each side.The serial # should be stamped into the top of the frame rail on the left side just to the rear of the bell housing mount,or on the bracket under the gas tank behind the tool box Good luck Dean Minn
Post A Followup
: Re: Re: Re: F 20 OR F30
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
