Re: C hyd
Posted by gene b on March 29, 2003 at 04:49:20 from (67.251.189.142):
In Reply to: C hyd posted by kjm on March 28, 2003 at 20:31:40:
Yes rite where the lines go into the assy above the starter remove the plugs and tap the valve there. It wouldnt hurt to enlarge the pressure one to 3/8 pipe just take tube assy off and take it to a shop that has correct drill and tap. The samll line is pressure and the big one is return. You will have to add more oil capacity. You can do it over at the fill opening or any place in the return line i would add a small tank of about 1 gal cap. They usually put these in series with the fill plug.
Post A Followup
: Re: Re: C hyd
