Re: Stuck engines
Posted by gm on March 29, 2003 at 10:20:00 from (170.215.97.126):
In Reply to: Stuck engines posted by BEL@IN on March 29, 2003 at 06:14:33:
I would say it is the condensation from
temp changes. Perhaps if you live
in a desert, it would not be a problem.
I think it takes some 5 years to actually
happen. Probably takes a while for all of the
oil slide or evaporate off the cylinders.
Its really not that much rust
in many cases, just enough. Like each
cylinder is stuck a little, so the amount
of pressure to break them all free is
quite a bit. If the exhaust was left uncovered
you probably will have to tear the engine
to pieces.
-Greg
Post A Followup
: Re: Re: Stuck engines
