756 HYD AND REAR END OIL
Posted by lenray on March 29, 2003 at 11:37:19 from (208.153.180.96):
I drained all of the oil out of the tractor HYD OIL. Do I put all of the oil in where the dipstick is or are there other plugs where I need to put oil in to get into the rear end and axles etc.
Also there is a little drip of oil on the cover where the filter is located I didn't use form a gasket or any of that blue stuff on the gasket---if I need to pull that plate off will I loose all of the oil or just a small amount coming out where the filter is located.
Any help will be appreciated.
Post A Followup
: Re: 756 HYD AND REAR END OIL
