Re: gas lever
Posted by Michael Soldan on March 29, 2003 at 16:46:15 from (216.46.130.20):
In Reply to: gas lever posted by 46 m on March 29, 2003 at 12:35:31:
46M, sometimes we think the toothed plate is too worn , when it is the lever that is the problem. I removed the lever, ran a bead of weld across the surface that contacts the inside of the plate and the lever now stays in the notch...just 50 or so years of wear....Mike in Exeter Ontario
Post A Followup
: Re: Re: gas lever
