Re: farmall AV manual lift converision
Posted by gene b on March 29, 2003 at 17:40:40 from (65.230.144.42):
In Reply to: farmall AV manual lift converision posted by cdv on March 29, 2003 at 17:29:34:
To put a hy system on an AV you need to add a hy pump either to the pto or run one off the gen belt or run a shaft out the front of the engine off the fan pulley. You can also run one off the belt pulley.
Post A Followup
: Re: Re: farmall AV manual lift converision
