Re: Re: Re: Re: C hyd
Posted by gene b on March 30, 2003 at 07:55:34 from (65.230.144.115):
In Reply to: Re: Re: Re: C hyd posted by Brian Schmidt on March 29, 2003 at 18:33:05:
I just worked on one that was done that way. The stock tubes that were on the fast hitch models were basicly that way only had outlets on the bottom of the block that i described as the flow goes thru the lines all the time under pressure so hook the aux valve in line with the return as i described and it will work. Doesent make any difference where the levers for the rockshaft are as the pump is pumping thru the lines all the time.
Post A Followup
: Re: Re: Re: Re: Re: C hyd
