Re: Re: Re: 300 u dies under load
Posted by Bob M on March 30, 2003 at 12:07:14 from (66.66.123.133):
In Reply to: Re: Re: 300 u dies under load posted by Duane on March 30, 2003 at 10:37:47:
OK - recommend you double check once more for something floating around in the bottom of the tank and getting stuck in the fuel outlet. Try removing the sediment bulb assembly (unscrew it out of the tank), dumping a gallon of fresh gas in and then catching the gas in a container as it drains out. Check the gas carefully for any "junk". If you find anything, remove the tank and give it a thorough cleaning. If it's not that, there may be something inside the carb bowl that periodically gets sucked into the main jet. Only cure is to remove, disassemble and thoroughly clean the carburetor. Could also be an intermittantly sticking float as you suggested earlier. Next time the motor begins to starve for fuel, immediately remove the drain plug from the carb bowl. If you get just a dribble of gas suspect a sticking float. However if you get a solid steam, the float/needle valve are working OK - problem's gotta be with the high speed jet. Again good luck!!
Home
| Forums
Today's Featured Article -
Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
