Re: Water water every where.
Posted by Rick(MN) on March 30, 2003 at 18:13:23 from (64.12.97.13):
In Reply to: Water water every where. posted by Kelly C on March 29, 2003 at 14:26:24:
Not to worry Kelly....you have neither the first nor the last farmall transmission to have a ton of water in it. about the only way to completely avoid water ever getting into them is to make sure they are parked in a heated shop ebery night of their life.
Post A Followup
: Re: Re: Water water every where.
