Re: M block
Posted by Farmall Daddy on March 31, 2003 at 04:33:09 from (209.183.116.216):
In Reply to: M block posted by Laughs Like thunder on March 30, 2003 at 15:58:48:
You can bore them out to a 4 1/8 inch, which was what I did. You can get custom made pistons for it and bore it to 4 1/4, but it is hard to find them. I was planning to buy another M, bore it out, and not run sleeves in the block, but just have the piston run along side the cylinder walls.
Post A Followup
: Re: Re: M block
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
