Re: Re: Re: Swinging drawbar--why are they better than a plain drawbar?
Posted by Dan in Ore on March 31, 2003 at 08:19:03 from (198.81.27.15):
In Reply to: Re: Re: Swinging drawbar--why are they better than a plain drawbar? posted by Michael on March 30, 2003 at 21:31:52:
When I use a swinging drawbar for pulling a plow, a disc etc. I set the pin on the right side of the drawbar so that when I am following the furrow with the tire the implement is in the proper position. I leave the left pin out so that when I turn it will allow the drawbar to swing that direction and turning will be easier.
Just another way of doing things, don't know if it is right or wrong, but it works for me.
Dan
Post A Followup
: Re: Re: Re: Re: Swinging drawbar--why are they better than a plain drawbar?
