Re: Re: Re: Gearbox oil pressure warning question on IH 484
Posted by Bernard le mécano on March 31, 2003 at 19:07:22 from (142.169.50.26):
In Reply to: Re: Re: Gearbox oil pressure warning question on IH 484 posted by Ted Mount on March 30, 2003 at 00:59:52:
Hi Ted, it's not hard but you spend much time to fix it. You may have to drain oil, then remove PTO clutch pack and gear. Remove MCV with hydro pump for access, then pressure pipe, strainer and drive gear from the transfer pump. The pump is secured by an allen screw, under the transmission housing. You may have to use the old strainer for the new pump, the new one is not easy to replace.
Bernard le mécano Québec Canada
Post A Followup
: Re: Re: Re: Re: Gearbox oil pressure warning question on IH 484
