Re: 300 Utility rear axel
Posted by Aces on April 02, 2003 at 07:52:12 from (205.187.82.195):
In Reply to: 300 Utility rear axel posted by Jim Hughes on April 02, 2003 at 06:55:37:
You can do it through the PTO drain the oil out and pull the pto take cap off end of axel then take one cap screw loose on in side of bull gear and put a spacer between that cap screw and the other cap screw of the other axel and as you screw the first cap screw out it will push that axel out then loosen the other cap screw and put spacer between that srew and the first bull gear take cap loose on end of the axel and as you back that cap screw out it will push the axel out. you have to move the bull gears back a little and to the other side to get at inside bearing or remove axel housing . if axel housing gasket is not leaking I would do it from pto. once you get the bearing out and get part number a good bearing supplier should be able to save you money. I did steering on my B and got everything from Motion Industries even seals. hop this helps
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
