Re: Re: Re: Re: Re: What's it cost?
Posted by I'm Cheap on April 02, 2003 at 09:19:05 from (65.141.162.194):
In Reply to: Re: Re: Re: Re: What's it cost? posted by Blain on April 01, 2003 at 21:35:15:
Its all in what you want to to do. I hand sanded and primed all the sheet metal and gas tank on my M then a buddy of mine shot the paint (Van Sycle(?) impliment with hardner). It ran about $65. I then brush painted the castings and the rims (after many, many hours of sanding and cleaning). I didn't paint the engine except for the oil and air filter covers, with all the grease cleaned off it looked like new anyway. The engine ran fine so I didn't screw with it other then pulling the valve cover to check the lash and pull the oil pan to clean the sludge. For about $175 (including decal set) I got a very presentable tractor. Some guys would go nuts about the kind of paint or using a brush, but as a weekend warrior it looks very sharp. I was lucky that the sheet metal was in very shape with just a lot of fade and only one previous aftermarket paint job to remove. When its not being used its in a shed so the paint I put on should look good for a decade or more.
Post A Followup
: Re: Re: Re: Re: Re: Re: What's it cost?
