Farmall Tractors Discussion Board
Re: Throttle Lever for M?
Posted by Ralph on September 11, 1999 at 15:56:09 from (207.109.126.15):
In Reply to: Throttle Lever for M? posted by Michelle on September 11, 1999 at 09:34:41:
Michelle: If this is the old throttle lever with a v shaped edge on it you may want to weld and form a new v to catch on the plate. This is an easy fix and will work for a long time. good luck
Post a Followup
: Re: Re: Throttle Lever for M?
