Re: old tractors grinding when you try to put them in gear
Posted by CNKS on April 02, 2003 at 17:43:27 from (207.178.96.212):
In Reply to: old tractors grinding when you try to put them in gear posted by ryan on April 02, 2003 at 16:28:25:
There is no adjustment. The gears are not synchronized. Use of 140 trans fluid instead of 90 will help some. Put rpm at low idle and wait a few seconds. Wide open throttle guarantees grinding. Usually only occurs the first time you push in the clutch. Should not occur to any great extent when shifing up or down (quickly) on the fly unless you shift to neutral and release the clutch for some reason.
Post A Followup
: Re: Re: old tractors grinding when you try to put them in gear
