Re: old tractors grinding when you try to put them in gear
Posted by gene b on April 02, 2003 at 17:58:37 from (67.251.189.43):
In Reply to: old tractors grinding when you try to put them in gear posted by ryan on April 02, 2003 at 16:28:25:
The pilot brng in the crankshaft is probably dry by now and worn after 50yrs or so it has a right to be. If you replace the clutch sometime and then also put in a new pilot bng and the rite lube the condition will improve much.
Post A Followup
: Re: Re: old tractors grinding when you try to put them in gear
