Re: Hunting in Idle position
Posted by Kerry Miller on April 02, 2003 at 19:37:57 from (65.90.147.133):
In Reply to: Hunting in Idle position posted by Vincent on April 02, 2003 at 17:54:59:
Just another thought - if it's been sitting for a while, it may be that the idle jet is a little bit clogged up. If it idles at all, it's not completely clogged, so it will probably fix itself. If changing the idle mixture or messing with the choke doesn't change things, that might be it. Like the other problems the guys mentioned, it may fix itself if you run it for a while with fresh gas and maybe run a little Berryman's through it. If not, (assuming this is the problem) you might have to run a little piece of wire through the idle circuit.
Try letting it fix itself first, that's always the easy thing!
Kerry
Post A Followup
: Re: Re: Hunting in Idle position
