Re: old tractors grinding when you try to put them in gear
Posted by Rick(MN) on April 02, 2003 at 19:55:47 from (64.12.97.13):
In Reply to: old tractors grinding when you try to put them in gear posted by ryan on April 02, 2003 at 16:28:25:
If everything is right in clutch, gears should not grind after 2-3 seconds in the winter and 3-5 seconds when it is warmer. A couple of common problems I have found that make them "grinders" are a sticky pilot bearing and clutch dust and rust building up inside the flywheel. Another common problem is the clutch disk not sliding away from the flywheel when the clutch disk is released because of either rust or a buildup of crud on the input shaft. In all 3 cases, it is a cheap fix. In extreme cases, the input shaft have serious grooves worn in it from the clutch disk that it drags on the flywheel when released. This is more common in tractors with a TA, but I have almost never seen it on the older ones. Rick
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
