Farmall Tractors Discussion Board
Re: Re: Fuel Line for MD
Posted by Ike on September 11, 1999 at 17:44:47 from (206.27.37.47):
In Reply to: Re: Fuel Line for MD posted by Ronnie on September 09, 1999 at 21:04:10:
Hey Ronnie, it's good to hear from you. As you probably remember I've had a low fuel pressure problem for some time. I discovered this pin hole in this line. Was the org. lines copper of steel? I've never had much luck trying to make such lines Over the years I,ve tried a lot, I've gor benders and everything but haven't had much luck. I'll try again and let you know. I would give you my E-mail address but I've never been able to figure out exactly why mine don't work just right. It.s nice weather in piedmont North Carolina today, high's is high 70's. Thanks alot for your help.
Post a Followup
: Re: Re: Re: Fuel Line for MD
