Re: Re: FARMALL SUPER C
Posted by ZR-1 PULLER on April 03, 2003 at 16:39:39 from (209.142.150.74):
In Reply to: Re: FARMALL SUPER C posted by BIG JOHN on April 03, 2003 at 14:53:52:
80 ft pounds total,now start from the center bolts working in a circular pattern out.Start out with 20ft# then 40ft# then 60ft# then 80ft#,after tractor has been run and warmed up set torque wrench to 80ft# and check bolts,if you follow this as out lined you will never have head gasket leaks.
Post A Followup
: Re: Re: Re: FARMALL SUPER C
