Re: Need help on brakes and pinion on 400
Posted by Aces on April 03, 2003 at 19:15:19 from (205.187.80.72):
In Reply to: Need help on brakes and pinion on 400 posted by Carp on April 03, 2003 at 17:00:45:
You can change the out side Bearing without moving bull gear but not the in side and it will come out with the brake shaft after the brake is off there is 2 plates the first one looks about 1/2" thick but it goes in side the other one to hold the seal and no screws i it it should come off with a little screwdriver ply if you need to replace the inside brg you will have to remove the axel and movr the bull gear back a little and off to the other for the pinion housing to pas the bull gear
Post A Followup
: Re: Re: Need help on brakes and pinion on 400
