Re: A Farmall front wheel change-out
Posted by Hugh MacKay on April 04, 2003 at 02:44:18 from (216.208.58.178):
In Reply to: A Farmall front wheel change-out posted by gurley on April 03, 2003 at 19:20:15:
You would have to go all the way to a 140 to get a hub for pressed steel wheel. The tractors you mention all are basically same as yours. This might take a lot of searching, and if time is money to you, I have a suggestion.
You can take your old wheel and bearings, go to any good bearing shop or light trailer shop, and they can match up a hub and bearings for just about any wheel you choose. It will cost about $50. per wheel. Find your wheels ahead of time, most 15" wheels off smaller cars work well. Problem to watch is get them narrow enough and be sure tires are going to clear the front end parts on tractor.
Post A Followup
: Re: Re: A Farmall front wheel change-out
