Re: 706 Wide front
Posted by Steve on April 04, 2003 at 14:55:14 from (205.188.209.78):
In Reply to: 706 Wide front posted by Everett on April 04, 2003 at 10:34:48:
Everett,
Try Mike at Franzen tractor parts in Monmouth 563-673-6691 (Close to Maquoketa). Wide fronts normally run between $500-$700. Also, Call Lee Lind (formally Lind Imp.) at Colfax, he has several 706 that have most of the parts taken off, but rear case is still intact. I have a 706 with the standard drawbar like you describe. To add a factory fast hitch or 3 pt., you will basically need to change most of the internal parts in the rear case, plus add all of the hitch linkage and draft control. It would be good to have a parts tractor setting there!
Post A Followup
: Re: Re: 706 Wide front
