Re: old tractors grinding when you try to put them in gear
Posted by JIM on April 04, 2003 at 20:43:54 from (67.250.198.206):
In Reply to: old tractors grinding when you try to put them in gear posted by ryan on April 02, 2003 at 16:28:25:
Had a problem with my M. Replaced the clutch disk, pressure plate, throw out bearing and pilot bearing. Still would grind with all the adjustment I could get out of the clutch rod. I had a badly worn clutch pedal and cross shaft which the clutch and brake pedals turn on. rebuilt the shaft and everything worked well.
Post A Followup
: Re: Re: old tractors grinding when you try to put them in gear
