Re: OT-moving 25x 30 ft grainery
Posted by Mguy on April 05, 2003 at 08:16:26 from (63.66.233.95):
In Reply to: OT-moving 25x 30 ft grainery posted by jmyt_47 on April 04, 2003 at 09:30:27:
Smaller bldgs can be moved with a hay wagon, trailer, what ever you got. Open one end, back conveyance in, deflate tires, nail cross members in , remove anchors from earth and air tires. If you need a lot of clearance dig holes to back into before deflating tires. Early on weekends is best time for "informal" moves. Big wide bldg you're talkin', use light poles for runners. Definitely cross brace. Good Luck !Mguy.
Post A Followup
: Re: Re: OT-moving 25x 30 ft grainery
