Re: 560 gas wiring
Posted by Bob M on April 05, 2003 at 13:11:55 from (66.66.123.133):
In Reply to: 560 gas wiring posted by LS on April 04, 2003 at 17:55:30:
Presuming you're using the existing wiring harness on your 560, here's a quick step-by-step: 1 - Label the wires connected to the voltage regulator (there should be 4 of them). Also label the 2 wires connected to the generator. Then remove the old regulator and generator. 2 - At the regulator end of the harness, connect the BAT, GEN and L wires together. Tape the wire that's left (FLD) - it won't be used. 3 - Mount the new alternator. Connect the existing generator A wire to the alternator BAT terminal. Tape off the existing generator F wire - it won't be used. 4 - Connect a short jumper wire from the alternator BAT terminal to the alternator #2 spade terminal. 5 - Run a new wire from the switched side (NOT the hot side) of the ignition switch. Run this wire to one side of an UNGROUNDED indicator lamp holder. Then from the other side of the lamp holder run to the alternator #1 space terminal. Use a #164 or #192 side marker/instrument panel bulb for the warning lamp. (You can substitute 10 to 40 ohm, 5 watt resistor if you don't want a warning lamp.) If you've wired it correctly, the warning lamp will light when you turn on the ignition, then go out after the motor starts and the alternator begins to charge. Good luck!!
Home
| Forums
Today's Featured Article -
Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
