Re: this DANG farmall wont start
Posted by gene b on April 06, 2003 at 04:56:47 from (65.230.144.92):
In Reply to: this DANG farmall wont start posted by steve on April 06, 2003 at 04:50:13:
First thing check the rotor and see if it is lined up with the terminal on the cap when #1 is on T.D.C. Simple way would be take all plugs out then clamp #1 plug to ground so you can observe when it fires and turn engine over and with your pinkey in the hole you can feel the compression and watch for the fire at the same time.
Post A Followup
: Re: Re: this DANG farmall wont start
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
