Re: idle screw useless
Posted by Janicholson on March 29, 2009 at 15:05:34 from (64.83.193.190):
In Reply to: idle screw useless posted by karl f on March 29, 2009 at 11:29:55:
A high float level will do it, as will an idle jet (where the screw goes in) that someone has plugged up. It should be richer turned in leaner turned out. Thus a thought might be that the passage that supplies air to the back side of the needle might be plugged or blocked by gasket material. JimN
