Re: 424 IH pto
Posted by Gary-Miss on April 07, 2003 at 12:14:31 from (152.163.189.203):
In Reply to: 424 IH pto posted by andy kohler on April 06, 2003 at 18:12:05:
I have a B-414 which has the same set-up as yours. You may just need to give it a little more adjustment since i will disengage under a load. The first step is the ground drive and the second step is the PTO drive. I had this problem a couple of years ago; One of the three bolts were broken that goes from the finger to the pressure plate. You can check this by taking theplate off under the clutchhousing and looking up through the hole. Get someone to bump the tractor over. Make certain is out of gear, etc. If you will E-mail me, I can check to see if you can change the bolt without splitting the tractor. I've still got the old pressure plate.
Post A Followup
: Re: Re: 424 IH pto
