Re: Post Hole Digger on a Super A
Posted by Haas on April 07, 2003 at 13:49:54 from (206.228.243.127):
In Reply to: Post Hole Digger on a Super A posted by Doug in WA on April 07, 2003 at 13:42:33:
About any hole digger will work with your 3 point as long as the PTO shaft does not interfere with things. I think if the hitch system on the digger has an inverted "U" shaped piece that hooks to the bottom lift arms it will work. I used a borrowed digger with the 3 point on the 140 I once owned. It worked great, but I don't know what brand the digger was. One advantage you have is that the 3 point can put some down pressure on the digger which is a big help if the ground is a little on the hard side.
Post A Followup
: Re: Re: Post Hole Digger on a Super A
