Re: Timing on H
Posted by Wayane Swenson on April 07, 2003 at 19:16:02 from (66.228.233.124):
In Reply to: Timing on H posted by Dan on April 07, 2003 at 18:14:15:
If the crank is positioned at TDC #1 cylinder; clamp the mag down at the point where it fires #1 plug wire. (impulse trips)
This should put you within 1 or 2 degrees of being "right on".
I use the same technique on battery ignitions for cars, trucks, & tractors. Oh yes, garden tractors, too.
Post A Followup
: Re: Re: Timing on H
