Re: Timing on H
Posted by gene b on April 08, 2003 at 04:51:54 from (65.227.11.95):
In Reply to: Timing on H posted by Dan on April 07, 2003 at 18:14:15:
That is the way to do it. There is no way to advance the timing with the mag it fires on TDC then when it runs goes to like 34deg. The only way to advance timing of the mag would be to change the base of the mag and like other post on this page said there was such a thing from I-H. I put a fire crater set in a B and it would not start until i changed over to a dist as with the dist timing could be advanced to start. There was a directive from I-H that when a fire-crater was installed you needed a dist so it would start.
Post A Followup
: Re: Re: Timing on H
